Front Mounted Sickle Bar
Rivertrac
B2620, LA364 Loader, RCK60-29B MMM, B2781 Blower, 48" KK Tiller,
Nov 17, 2011
Grand Rapids, MN
Been toying with this idea for the past couple years and thinking about using our B2620 with the front snow blower mount and fabricating a "socket" to fit the hitch like on the blower. Problem I am having is trying to figure out how to change the rotary motion of the PTO to a back and forth motion for the sickle. We have a 4 foot sickle bar that would be perfect so looking for ideas. :confused: Anyone have any viable suggestions?
8,077
To power the sickle bar, you would need a arm hooked to one side of the ratating portion. So when it is at 3 o'clock it has the teeth extended all the way out and then at 9 o'clock the teeth are retracted the other way.
Seems like it would put a lot of stress on one side of your drive train. The one we had was a 3ph mount and was counter balanced on one side to balance the weight of the arm
ShaunRH
L3200
May 14, 2014
1,414
Atascadero, CA
I don't know if you have an FEL or not with that unit or front hydraulics, but you could use hydraulics from a PTO or even direct electrical with a home made electric actuator system. You could even use a custom built reciprocating hydraulic system (not a standard pump). The PTO could turn an eccentric that pushes a hydraulic ram in and out, which pushes a ram attached to the sickle bar, I'd use really small rams! You could do the same pneumatically.
I can think of about a dozen ways to do this, and have drawings I rigged up to do a 20hp Craftsman lawnmower using it's mower belt drive. The hard part is the hardened sickle bar!
Rivertrac
Nov 17, 2011
Grand Rapids, MN
In retrospect I probably should have included a photo of what I am trying to accomplish. The snow blower hitch has a PTO drive line mounted in bearing blocks which should handle any loading. I need to figure out some sort of excentric link to handle the rotary to back and forth motion but what I really need to know is what RPM I need to get the right cutter motion. I think 540 is too fast and would wear out the sickle rather quickly. Any one have specs for this?
8,700
Your really going to have issues, the mid PTO does not spin at 540RPM it Spins at 2500RPM you will need a reduction gearbox and a concentric drive to make it work.
IMHO your going to cost way more than the worth to make it work for you, but I like making things that are out of the ordinary for my tractor.
Tooljunkie
May 13, 2014
4,150
Getting a 5:1 gear ratio is easily doable with belts,a sickle doesent require a lot of power to operate, biggest hurdle is getting the stroke length correct.
I see only a few times where a sickle mower would be useful, hardly worth putting in front, in my case the offset type is more useful (under trees and mowing ditches and wet areas where i cant drive tractor)
8,700
On the negative thinking side of things, first time that thing digs into something it's Toast! :eek: Tractor would just push it till it became a pretzel! ;)
8,077
Foolish question. Is the sickle bar already mounted to a 3ph?
Rivertrac
Nov 17, 2011
Grand Rapids, MN
The B2620 has two speeds for the mid PTO if I remember the manual correctly but will have to reverify that.
Yes I agree there are not many uses for a front mounted sickle and under trees is my primary intended use. I will have to be very careful regarding hitting something in front of the sickle which will be riding on skids plus the snow blower mount has hydraulic lift. If I can put together a workable solution then the next mod would be the ablility to shift it to one side or the other for more versatility. Also the sickle is not mounted to a 3 pt, I think it originally came off a Gravely walk behind.
Tooljunkie
May 13, 2014
4,150
Hyrdaulic drive would be the most practical in regards to versatility. Then it could be mounted in a spring- loaded type of coupler, in case of contact with something. My sickle pops out of a socket if i tag something. Pto pump and a motor on mower. Could plumb hoses and tank, no control needed. Maybe a valve to set speed.
One thing i find that escapes me is the knowledge to figure out pump and motor volumes. Im assuming pumps that can be converted to motors would be the most practical- then buy two the same. Convert one and- dere ya go....
Rivertrac
Nov 17, 2011
Grand Rapids, MN
Project-X: No bucket/FEL involved, just the snow blower hitch.
Tool junkie: hydraulic drive wasn't a solution I had given much consideration. Looks like I need to review more closely, I'm starting to like your ideas!
