front axle L1500DT
Lotsarocks
L1500DT zen noh, 4' brush hog, ford 4' finish mower, 6' rock-landscape rake
Feb 9, 2016
Midway, Ar.
Hi all,
I need help finding front axles for my l1500dt.
Also are both sides the same?
Thanks for any and all help.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
4,023
368
Williamstown Ontario Canada
I don't know how much help this will be.
In the list to Gray and equivalent USA machines there is only a L175 listed as being equivalent to your L1500DT. The L175 is not DT.
In the same list, there is a L1501DT with an equivalent listed as L185DT.
Messicks shows LH and RH front axles for the L185DT. They are not the same!
Dave M7040
Monza1234
Kubota L1500DT
Jun 1, 2021
Germany
Thanks Bill
That helps a lot. I have a axle on the way.
I'm guessing Kubota will have the seals, studs, & lug nuts.
Heres some pix.
I hope this works!
Hello, I have a question.
Where did you buy your axle and seals? I need a new axle, and I don't know where to find one.
Thank you in advance.
Ikc1990
Kabota b2710, cab, la402, b2782, 5' bush hog, homade carryall, 5' rototiller,
Dec 2, 2020
157
61
Vermont
So I'm rebuilding my b2710 front axle changing all seals, bearings etc kubota dealer had to order all parts non in stock locally.
