Front Axle Case Oil - Change at Interval or no?
MOlivin
L6060
May 15, 2023
37
MO
Hi all,
Just picked up a '14 L6060, almost has 600h on it. The dealer I picked it up from did the following services on it:
Engine Oil & Filter change
Fuel Filter change
Fuel Filter Separator change
Air Filter change
Trans Oil change
Trans Filter change
HST Filter change
However they do not change the Front Axle Case Oil. I asked why as it's in the service manual? They said they don't change that unless it's leaking and needs to be refilled. They have never changed the axle oil as maintenance.
Question is, should it be changed? Or leave it alone as the dealer said?
If we do need to change it, what do you guys use?
Thanks all!
edisonck
MX5800, RCR1872 Rotary Cutter, DH2596 Disc Harrow, Ford 860, Ford 3-bottom plow
Mar 9, 2020
39
Chaska, MN
I bought a new 2019 MX5800 and my front axel fluid was WAY low- as were many others based on other posts. That said, if it was my tractor, I would change the fluid and replace with Super UDT2. Keep in mind that I am an "ounce of prevention equals a pound of cure" kind of person.
4,150
Hi all,
Fuel Filter change
Air Filter change
Trans Oil change
Trans Filter change
HST Filter change
Thanks all!
Do you change the gear oil in the differential of your car every 30K miles?
Similar amount of wear time.
3,012
As already noted…the front axle is often found to be under-serviced from new.
I’d drain whatever is in there (likely UDT/UDT2/etc) and replace it with 80W90 gear oil for the rest of its’ life…and never again unless it is required for other repairs. Why?
Because the front axle gears are used very little in comparison to the rest of items on the tractor and gear oil will outlast most owners.
The 30K differential oil changes suggested by most newer autos is a waste in my opinion. I change mine every 100K. And my background is a rear-axle specialist-technician trained by Gulf States Toyota Factory school on rear axles and differentials. (Paid my way thru college and flight-school doing that.)
(Think about this…. Most folks agree that synthetic oils will outlast common standard oils. Most modern diffy’s leave the factory with multi-grade synthetic oils. So why are they suddenly in need of 30K mile changes when grandad’s ‘62 chevy/ford/dodge which used gear-oil never needed that? I believe it’s for two reasons: One-it makes more money for dealers who up-sell other items while the vehicle is in-service, and Two- because it is further underwritten by an associated warranty which forces the issue.)
I don’t buy extended warranties….and I change mine every 100K because, One-that’s what has worked successfully for my rear axles for 40+ years, Two-the modern synthetics also have a non-slip additive for the vehicles I own which Does need refreshing. I’ve had Zero rear differential problems with this practice. YMMV
Hope this helps.
The Evil Twin
L2501, LA526,
Jul 19, 2022
2,383
2,293
If you never use 4wd it'll outlast you. If you do, then you should add the service in somewhere. Helical and hypoid gears do a lot of sliding. Oil breaks down over time.
If you plan to use 4wd a good bit, change it now. Then maybe after another 500 or 600 hours if, like a lot of us, 4wd is never off.
I'm with Geo on the interval thing. For a vehicle, 30k is crazy. I do the truck at 60k but half that is towing pretty heavy. Haven't touched the front diff in the truck though.
JasonW
236
100
Al
Change it. I change mine the same interval as the hydraulic/transmission fluid. I use Super UDT-2. The manual calls for Super UDT-2 or SAE 80- SAE 90 gear oil.
Go down that rabbit hole on which is better.
Just looked at the L6060 manual, recommend changing every 400 hours. Same as transmission fluid, and engine oil.
4,150
Hope this helps.
EXACTLY !!!!
Smokeydog
Jun 2, 2020
572
526
knoxville, Tennessee
Drained the M59@1100hrs and B26@400hrs front axles. Both were surprisingly dark in color. Replaced with 80-90wt gear oil. Synthetic Lucas in the B26. On our hillside farm they stay in 4wd almost full time.
Older 4x4 Kubotas did the same as advised by the dealer. All with FELs and no front axle problems.
MountainMeadows
Jun 6, 2022
193
255
Poconos, PA
I've been in the transmission + differential business for 40 years. What's the most common cause for failure in these areas? Lack of preventive maintenance.
An ounce of prevention is worth a pound of cure. When in doubt examine the fluid in question. If it's dark or black in color it needs changing.
Regardless of how often 4WD is used, those gears are always turning when the tractor is in motion. Obviously, when 4WD is engaged, that's when they are under load, and the more often it's used, the sooner the fluid will need changing. Even if you never use 4WD the fluid will break down over time and need changing at some point.
The Evil Twin
L2501, LA526,
Jul 19, 2022
2,383
2,293
I did mine at 50 hours and it was coffee colored. (Man style coffee, not half double shot triple pump, hold the whip, extra foam). After checking it at 40 hours and found it low, I topped it up. Ended up overfilling a little. What came out was dirty enough to make me spend the extra couple bucks and change it.
I know, I know. Color is not an indicator of service life. But, it did give me a warm fuzzy feeling.
Smokeydog
Jun 2, 2020
572
526
The front axle on the M59 took overnight to drain and several days of topping off to fill. 11 quarts.
3,012
Helpful hint: When re-filling a unit… First, determine if the amount in the unit is FULL …according to whatever indicator the manual states….., THEN ascertain the amount which actually drained-out. Compare that to what the manual claims is the capacity.
Then, refill slowly until the “full” indication … (whatever that may be on your equipt)…. and see if it, ONE-agrees with the manaul, and TWO is similar to what you drained out.
Something I have found helpful: I bought a brand-new pump-up-type garden sprayer….and tossed the spray-head in the trash…. using the hose and valve-controlled-wand to distribute the fluid.
The tank should be marked for quantity….if not, do so yourself as you fill the sprayer tank with the fluid you chose.
I have one of these set up for gear-oil…. Another set up for Hydraulic Fluid…. Others set up for other specific uses. They are often less than $15 each and are opaque, allowing me to see how much is contained and how much is distributed.
Buying some fluids..such as diesel engine oil…hyd fluids…. gear oil….etc etc …in large containers to be poured into the garden sprayers…. makes it possible to buy often-used fluids in bulk / at-discount.
Hope this helps.
MOlivin
L6060
May 15, 2023
37
MO
Thanks for the help everyone, I'll pickup the 3gal. of Valvoline 80/90 needed and get this taken care of. I like the idea of the pump sprayer, simple way to measure and force the fluid in there quicker. We'll see what the quantity is in there and will report back.
After going over the services the dealer preformed I noticed that instead of using UDT2 for the hydro oil... they used John Deeres hydro oil (the dealer I bought the L6060 from is a JD dealer) however they did use all Kubota filters. Can't find any spec info on the JD's ty22062 vs super udt2 to make sure it's equivenlnt. I'm opening a new thread for this so this one does not go askew.
3,012
Ask your JD dealer how He would view someone using Kubota fluid in a JD>
