Finally found an answer to the big question.
Rob
B6000DT / B7100DP /B8200DT/L225/Globe PTO Chipper/Lewis Backhoe/huxley TR66
Nov 22, 2009
679
Leafy England....
Well then guys, i've finnally found the answer to the big question, "what size tyres" do i need.
if you need to replace the rubber on your machine and want to use something else, such as, a truck or 4x4 tyre to use on grass etc, and need to find an alternative but are lost in a minefield of data, may i suggest you look at these two sites.
1)www.dakota-truck.net/TIRECALC/tirecalc.html
2)http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=46
the first is really good, i've tested it out with certain manafactures tyre data and its spot on.
the second will help you with conversions also and how to make the calculations.
give them a look, you can only be more enlightened from it, it may also help you out.
so if you need, let say like me a pair of 27x8.50-15 tyres with the help of these sites you can get a very close, if not ,spot on alternative.
hope it help, it has been a great help to me today.
cheers
Rob:cool:
