Engine locked up
Adf
B7200HST
Nov 23, 2019
46
Joelton,tn
I own a b7200hst 4wd. Saw another 7200 2wd For sale That had a nice front end loader so i bought the whole tractor planning to put the loader on my tractor.
It was advertised “Engine problems” . Turns out the man was mowing with it snd it just conked out snd the motor wouldn't start Or even move when starter engaged. So he dragged it home and bought a new kubota And sold this one “as is”.
i wonder what locked up in it?
Interesting is that there is no fuel in fuel tank.
Cant move the engine with starter or by hand but no holes in block . No water in oil or metal ( that i can see).
How would youall proceed figuring out whats wrong?
(I do have a downloaded manual)
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,128
933
Williamstown Ontario Canada
If currently it wont turn over by hand or starter, remove the glow plugs and then try to turn over.
Watch for any fluids shooting out of the open GP hole.
If it wont run over with the GP's out then there is likely serious damage.
Dave
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,128
933
Make certain the clutch is disengaged to rule out any transmission issues
Dave
BX23S-1
535
197
No where Special
Can you get a socket with a big breaker bar on the crank and try to see if the engine is actually seized? Could even be something locked up within the driveline, so obviously the engine wouldnt turn over to easily.
Adf
B7200HST
Nov 23, 2019
46
Joelton,tn
I’ll try it
BX23S-1
535
197
No where Special
I’ll try it
Check to make sure the starter isnt engaged and locked up as well. Worth a shot anyway. Without actually being there, hard to say what could be wrong. But, there are some pretty darn good guys in here that can try to help you. I`m basically just shootin in the dark at this point.
4,059
might get lucky and unwind the 300' of bailing wire on the mower deck......that might 'unstick' it. Though I assume you've got the PTO disengaged.. Maybe 'hydraulic lock'. pull GPs, try to spin. Check dip stick oil level...
I 'won' doing that to a 25HP gas rider one day.....
Adf
B7200HST
Nov 23, 2019
46
Joelton,tn
Dave
no way I’m getting the glow plugs out without taking what looks like an intake manifold off. How about removing fuel injectors? They look easy to access and remove
1,001
Either glow plugs or injectors out will let any fluid out and relieve any compression.
Injectors will require new sealing washers during reinstall and bleeding fuel if it spins.
Does it have any method of decompression? If so get advice on using that instead of removing anything. I can only assume that is okay to do but get experienced advice before proceeding that way.
3,032
If a healthy starter motor won’t turn it... You can probably guarantee to convert the engine to junk by getting a bigger breaker-bar and forcing it to turn against whatever has it locked up. (Hey! Just get a bigger hammer!”)
Forcing a broken rod or seized bearing to rotate can damage the more-expensive crankshaft/block beyond repair. Pull the injectors or GP’s and see if anything is in those cylinders.
Adf
B7200HST
Nov 23, 2019
46
Joelton,tn
Got it and good advice.thanks
Adf
B7200HST
Nov 23, 2019
46
Joelton,tn
Progress!!!
well i still could not get glow plugs out to check for hydraulic lock... but.
while i was reaching in to access crank nut i thought to grab the alternator belt and see if i could move the crank and it did move but only clockwise. actually moved all the way through a cycle or two. BUT i moved to try the starter again and it cranked but not very much and stopped. Backed it up again by pulling the belt and cranked the starter and again it moved but not to far and stopped.
what do youall think?
SidecarFlip
Banned
546
Sounds to me like it's time to take it apart and find out what is locking it up.
Adf
B7200HST
Nov 23, 2019
46
Joelton,tn
Yea . Thats what i was thinking too
Whats your best guess I’ll find the problem to be? Engine rotates smoothly backwards so i think i can rule out anything being seized. No grinding or knocking sound when it stops in forward cranking motion with starter?
perhaps a wrist pin broken?
N3BP
Sep 20, 2016
392
148
Lebanon, PA
Yep, the B7200 most definitely has a decompression knob. Give that a pull and crank it over....
rbargeron
Jul 6, 2015
1,150
219
western ma
Sort of a head scratcher - turning the engine back and forth, does it come to a hard stop or does it get tight over a few degrees? Same in both directions? When you bought it were oil and water levels full? Are they still?
