Engine damage from topping off?
Mossy dell
B2601 (2021) JD970 (1998) B2100 (1991) B6100E (1988)
Jul 20, 2020
274
125
sw VA
I saw an article in Consumer Reports reminding that squeezing extra gas into a tank can in time damage an auto’s vapor recovery system and cause major problems.
I realized I DO this—on my tractor. The pump seems to cut off otherwise so soon, with the diesel far below the full port.
But do today’s tractors have a vapor recovery system?! I am an idiot if they do though I never squeeze much extra in.
ve9aa
Apr 11, 2021
1,202
974
NB, Canada
I always do this on every car I've owned the past 40yrs.
I've been topping off for the last 13yrs on my current daily driver....2009 MINI. I fill it literally right to the gas cap, nearly every time. (on super hot days I might not for concern over expanding fuel volume)
I then drive a minimum of 25miles home, but sometimes 200miles or so on an alternate route.
There are now 230,000kms on the wee beast.
No issues.
No issues on the other 30 cars I've owned that I could attribute to this.....nor my motorcycle.
Yes, I realized you asked about a tractor....I do it on my 'BX & TG as well.
2,363
Wow! I'm impressed!
I too sometimes take alternate routes home...BUT never added 175 miles to the return trip!
I do enjoy the different views...but... :oops:
ve9aa
Apr 11, 2021
1,202
974
NB, Canada
Wow! I'm impressed!
Yeah, I didn't explain that very well. The 200 mile route is to a 2nd workplace, so I gas up before leaving, then go to #2 location.(not home)
4,027
whew !!!! man that'd be one painful detour..... worse than the 7 mile one I've had to deal with for 3 years...
PaulR
Aug 3, 2020
581
457
Hadley, MA
I used to top off my wifes 2013 Chevy Traverse. Wrecked the evap system, went into limp mode.
YMMV
Botamon
Mar 26, 2018
237
410
Winnemucca, Nevada
Probably depends on the particular vehicle as to whether topping it off hurts.
The evap canister on my 2007 E350 van is located in an awful spot behind the gas tank and between it and the spare tire. A few years ago I began having problems when fueling - the fuel nozzle kept turning off as if the tank was already full. This happened at many different service stations so it was not a bad fuel nozzle. Did some research and found out that by topping off my van completely was causing the gas to flood the evap canister, ruining it. I had to replace the canister. No more problems - and I don't top off the tank anymore, either!
But I don't think tractors have evap canisters.
OrangeKrush
Nov 15, 2020
1,047
514
Indy
Yep I learned my lesson on my 08 Silverado, never heard of such a thing! It's very irritating trying to pump gas to have it click off every few seconds. Now as soon as that thing clicks I'm done!
They just couldn't leave well enough alone !
2,363
What I have noticed, is that sometime the fuel input stops, even though I know the tank is not full yet. BUT our dispensers here, have two settings that turn off when they sense the fuel pipe is full. One is fast, and the other is slower. If the fast does not work, I use the slower setting. I don't top off...but the slower setting always seems to work, when the fast one doesn't.
CGMKCM
RVT-1100C, ZD323, L4760
Jan 26, 2021
372
175
Randolph county N.C.
Only top off issue I have (Diesel tractor, mower, car, truck) is when topped off cold weather and then it warms up and fuel expands and leaks a little from the vent.
notaz3
76
67
ID
Been fueling tractors (and Diesel trucks) for years to the point where level is up to fuel cap. Never had a problem.
Gas vehicles can be different depending on who their emission system is set up.
RalphVa
738
319
Charlottesville
Did it to the top almost every fillup on the 240D Benz for the 25 years we owned it and do it on the tractor all the time. There's no evap canister at risk on diesels.
3,010
I have my own re-fueling set-up for my diesels and all my diesels are off-road, I keep my diesels topped off (to the point where I can see the fuel just at the cap stand-pipe) to minimize condensation issues (which can add water that will wreck injectors)….but my gasoline vehicles are kept to whatever level the auto shut-offs are set at the public pump. When the nozzle clicks “Off”…. I’m thru. Never a problem. (and never an angry person waiting next in-line behind me either)
Here’s an extreme example of idiocy: Have you ever observed Mr Lunatic actually hold the delivery-hose over-head in an attempt to drain the hose completely after the nozzle has shut off? :rolleyes:
Outnumbered
Kubota L3901, FEL, BB1260, RCF2060, FDR2572, Titan Forks, Caryall, 5' Tiller
Oct 26, 2019
181
278
Moseley, VA
I have had the most issues topping of GM products..>I used to blame the evap solenoids as being junk and then read topping off the fuel is often the culprit. Stopped topping off and no more replacing evap solenoids ever 15k miles. Oh and to stay on track with the original question, I do not top off the tractor either even though it does not have all the emission components. :D
