I have a 2016 L3901. I bought it used with 1000 hours. I’ve put about 30 hours on it since getting it around 2 months ago. I’m having an issue with the EM dash light. About 10 days ago while tilling, I noticed the heat gauge was rising. It got close to the red zone, so I stopped tilling and parked the tractor. The EM dash light came on before I got it parked. The owners manual just say it’s EMissions and to check the coolant level. I had to go on a trip so I just left it.
When I returned from my trip, I checked the coolant level, radiator and radiator fins. All was good. I changed the oil and topped off the HST transmission fluid. Then let it idle for about 5 minutes. All looked good. I started tilling. About 15 minutes into tilling, I noticed the heat was starting to creep up. It got to about 3/4 on the dial and the EM light came on again. Then something very odd happened. On it’s own, the engine rpms increased, then decreases, then the tractor stopped running. A puff of smoke emitted from the muffler. It would turn over, but wouldn’t start. No fluids where coming out of the block or crank case. About 10 minutes later, it started right up. No EM light. I just parked it and lowers the implements. Any ideas or suggestions would be appreciated.
