EA Wicked Root Grapple for L6060
racerboy
L6060, RTV-Cab
May 10, 2021
159
140
NJ
Another shout out to the folks over at Everything Attachments! I ordered my Wicked Root Grapple last Monday, and they somehow got it to me in two days, just before Thanksgiving! I spent all morning on Thanksgiving driving around the property and cleaning up old dead trees!
Reactions: 11 users
9,865
View attachment 166322 View attachment 166323 View attachment 166324 View attachment 166325
Awesome grapple. Wicked 60 right? Good to see the EA is back up and running and producing great implements again.
GrumpyFarmer
4,459
That’s an awesome combination you got there!
I suspect you will find the BH to be awesome ballast (as well as much better than using a shovel) when using the grapple…you should feel very planted when lifting logs and debris.
WI_Hedgehog
Apr 24, 2024
930
1,292
Milwaukee, Wisconsin, U.S.A.
That grapple looks phenomenally new! Mine came with a dent and some poor paint prep resulting in missing/flaking paint, so I responded by using the heck out of it on rocks. That balanced out the paint look. :ROFLMAO:
They're really strong grapples. My center pin doesn't have grease zerks so if yours also doesn't make sure to manually grease the pins regularly.
2001TLB
L48TLB, 60" EA SSQA Root Rake Grapple, EA SSQA Fork lift
Nov 14, 2021
68
57
Shelton, Washington
I see they added a cross drilled pin to the cylinder/lid pivots. I bought my grapple from them in 2021. I was really happy with the attachment (and still am), except for the really goofy lubrication set up at the outboard pivots. I also was not happy with the response when I asked Travis how the stupid design was supposed to work.
I can't find the picture I took of it, so will try to describe it. A short piece of pipe was drilled, tapped, then a zerk fitting installed. This pipe fit (loosely) between the clevis fitting forks on the end of the cylinders, with an o-ring between each end of the pipe and the clevis forks. While greasing, grease just oozes out of the end of the pipe and does not get anywhere near the pressure points.
When I reached out to Travis at EA, he wrote something like- The grease will get where it needs to be...or something lame like that. Maybe I will reach out to them and see if the current design is retrofittable to my grapple.
Enjoy your new tool.
Doug
9,865
GrumpyFarmer
4,459
Well crap now you all have me festering about mine, but mine is raised to the heavens praying for Buckeye victory this evening as I type…As soon as mine comes back down to earth I am going to have to give mine a lookie-loo…damn tractor fanatic cult😉.
i can’t drop it before the game because of the GD SEC championship that SO seems to care about yet knows not a name of player or coach 🙄. And if I drop it during THE game I suspect I will have to wear my down hunting cloths and sleep in the observation tower tonight and hope I get to see some northern lights.
GO BUCKS!
AOW162435
'25 LX2620 / '79 B7100 / '03 JD x595
Jun 16, 2023
189
111
Ellicott City, MD
I purchased a Wicked Grapple for my LX2620 back in the Spring. Fantastic piece of equipment, great communication, and a painless transaction.
Andreas
Vahunter
Kubota L4310HSTC; Woods Ground Mover LC102 FEL; EA Wicked 60 Grapple
Mar 15, 2021
20
Doug
Y
You will enjoy your grapple. I have the Wicked 60 as well and something about using it makes a man's testosterone go up a few points! My only complaint with EA was the long lead times but it seems they may have taken care of that issue. Customer service is A+ and you can't beat the quality of their products. Enjoy!!
2001TLB
Nov 14, 2021
68
57
Shelton, Washington
I was wondering if it would be possible for you to post a picture or two of the hinge/cylinder pivots that show detail from above and a close up from each end of the pivot bolt/pin.
I reached out to EA, asking if my grapple can be retrofitted with the current cross drilled pin design.
I would appreciate it,
Doug
