Hi all, I have a 2008 toro z master with a 902d. I bought it with a spun rod bearing and rebuilt the motor. I bled the fuel and started right up and idled nicely. When I went to rev it up, I had no throttle, it just idled. So I assumed I hooked a spring up wrong or had an issue with the injection pump. I took it apart and was double checking the repair manual and found I did not install the rack pin in the fork lever correctly. Problem is I can't get the rack pin to slide far enough forward or the fork lever to go far enough back to get the pump to drop down in the block.
See how the cutout in the block for the rack pin sits directly over the fork lever. I'm about to pull the studs out and see if I get a little more wiggle room, but I don't think that'll be enough. I've been searching for a while/ maybe I'm just an idiot but I'm frustrated and can't get it figured out. Hopefully someone who's done this can shed some light on the situation. Thanks guys
Also I bought it already torn apart, so I kinda feel like I'm up a creek without a paddle if ya know what I mean
