Cold Weather Start Up of L3800
tsafa
Kubota L3800, FEL, F550 Dump, 10K Trailer
Nov 3, 2013
152
Tobyhanna, PA
I had a little difficulty starting up today. Not sure why. Below freezing out. Ice all over the tractor. Turned to key back for 10 seconds to heat up and then turned it all the way to the right. Nothing. The starter did not even turn.
I made several attempts making sure the tractor was in neutral and PTO off. Clutch down. Nothing. Starter was just not cranking. Fuel has cold weather treatment.
Then for no reason at all, it started right up. I let it heat up of about 15 minutes. Drove it around. Turned it off and attempted to start up. Nothing. No starter. After a few attempts. It started right up. If starter turns, it starts up.
I am sure it is cold related because I have not experienced this before. Only 30 hrs on the L3800 Tractor.
Any ideas what is going on here?
hodge
Nov 19, 2010
2,948
513
Love, VA
It sounds like the cold is effecting a safety switch. Is it a hydro? Next time, try touching the pedal forward or backward as you hold the key to start.
Is 10 seconds all that the newer tractors take for glow plugs? I would have assumed it would take more time.
WFM
L3800
Apr 5, 2013
1,452
858
Porter Maine
My knowing nothing about tractors, I actually watched a video here with Vic I think it was entitled "cold weather starting for morons like you WFM"....on that video he said sub zero starting , to hold the key to the left for one minute. That seems a long time as I was holding mine there 15 seconds. When the dealer dropped it off he told me to heat the glow plugs for 20 seconds.
Do you cover your tractor with a tarp to keep the snow and ice out of the electronics at all ? I'm sure they are sealed some but I would feel better if it was mine to cover the steering wheel area.
Vic also has a video "how to bucket snow with your tractor".....very intense.
m32825
L3800HST
Jul 12, 2013
215
25
Central FL
My L3800 manual has these preheat times:
Over 32F, 2 to 3 sec
32F to 23F, 5 sec
23 to 5F, 10 sec
Clearly, if it's below 5F you're supposed to find something else to do! :)
-- Carl
tsafa
Nov 3, 2013
152
Tobyhanna, PA
Its an HST. Yeah I was thinking the same that some safety switch is somehow being effected. I will try what you suggested about touching the pedal forward and back.
I do not have a tarp on the tractor. The dealer said it was not necessary and that the tractor was weather-proof. I am not against getting one if it would really make a difference.
-- Carl
Set on Fire ???
The 4x4 lever was iced over and I had to light up a torch to melt the ice and engage it today.
Bluegill
Jan 11, 2012
1,559
Success Missouri
HST pedal is the culprit most likely.
I never heat plugs more than 10 seconds.
Your tractor will last many, many more years if it's covered! The sun will do as much damage as the rain and ice. Please cover it, too nice a tractor to leave out in the elements!
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
All diesels are tempermental in cold weather. None of them like it when its cold and covered in ice. I haven't met a diesel yet that fires up without struggle and acts right in the cold without some sorta warm up.
bearbait
Dec 9, 2011
4,104
879
New Glasgow Canada
Last winter when I had my L3800 I would count to 20 with the glow plug on and then it would start no trouble every time.
gpreuss
Oct 9, 2011
1,166
Spokane, WA
There are two issues here, mostly unrelated. One is the preheat time. That heats up a glow plug in the cylinder head, to assist the diesel fuel compression in making enough heat to fire. It affects the ability of the engine to fire once it is cranking.
The bigger issue is that you turn the key and nothing happens. Serious cold shrinks metal and most insulators. It can loosen the battery terminals, change the length - just a minute amount - of linkages, alter spacing - again just slightly - of internal contacts, etc.
Does the tractor do anything while you hold the key on? Any dash lights? Any clicking from the starter? Any noise anywhere?
I'd check the battery connections, then head for the starter. Maybe the bendix isn't sliding because it is new and tight. After a while it kicks into place and cranks. Tug at all the wires you can reach - maybe you have a loose crimp in a wire connector somewhere. The problem is that after a while it does something, so everything is basically there OK. Some electricity must be flowing, to allow things to get hot enough to actually start conducting like it should.
I once had a new car. One time I got in it, and it was like there was no battery. No lights, no radio, sounds, nothing. I measured the battery voltage - 0V. I tried to charge the battery - no current would flow, even at 24V. So I jumped the battery to get the car started, and headed for the dealer. About half way there the charge indicator suddenly showed a charge, and the battery appeared to be working. At the dealer, they tested the battery, and it was A-OK! But they gave me a new one anyway. Strange things do happen.
Good luck with this. Let us know what you find.
lreops
L3400DT W/ LA463 FEL and L235DT W/ BF400 Loader
Dec 26, 2011
306
Rising Sun, Maryland
My bet is on a Safety Switch not making contact because of the cold, also. The Neutral switch on mind, even though I make sure it's there in the correct position, sometimes don't make contact with both of the switch contacts. Not sure if that would apply for a HST, but the same principle could apply with other switches. The questions gpreuss asked would help if a more detailed answer, especially on what is heard or not heard when the key is turned to the right to start.
Ron
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
A tarp is a PIA for the most part but if that's all you got I would cover that bad boy up. Now if it doesn't bother you that it's aging at a rappid rate and you are taking years of the tractors life then don't worry about it.
If it was me I would be looking at building a shed to store it under and all the implements as well. Even one of the cheap portable carports would be a step in the right direction.
Benhameen
Jan 27, 2013
713
135
Southern IL.
I'll preheat mine for 5-6 seconds, maybe 10 at the most and I've not had any problems starting mine at all. I keep mine in a barn that's unheated as well.
tsafa
Nov 3, 2013
152
Tobyhanna, PA
It was not a battery issue because the glow plug light lit up.Lights turned on. It is as if the starter died.... or one of the safety switches was triggered.
When the starter decided to wake up... the engine started right up... so the glowplug did its job fine.
This happened twice last night. The second, time after the tractor had already been running for 15 minutes, so I don't think heat/cold is the issue.
It started up just fine at 5am this morning (with ice all over the tractor) and I ran it for about 4 hrs pushing ice around the parking lot. I just tested it again now at 5pm after reading your post and again it started right up.
So far it is a complete mystery why the starter would not go yesterday and then then for no reason, start.
tsafa
Nov 3, 2013
152
Tobyhanna, PA
Ron
HST was in neutral, although it will start up even if in gear on mine. I did shift around a bit in case that was an issue.
I am thinking a safety switch too. I lifted and dropped the seat. The switch under the seat was free of ice. Moved the PTO ON and then back OFF. Made sure I was pressing clutch all the way down. Then stopped moving things. Turned the key a few more times with no difference. No sound. Turned it once more and the tractor just started up.
lreops
Dec 26, 2011
306
When it does not start, is there a click or any kind of sound when you turn the key? My thinking says that if nothing is heard, I'm back to an intermittent Safety switch. If you do hear something, I would then think Starter problem.
Ron
tsafa
Nov 3, 2013
152
Tobyhanna, PA
Ron
No Sound. I am thinking a safety switch. I just don't know which one. I guess there is nothing for me to do now, since the tractor is starting up just fine. I guess time will tell if this is an issue or not.
BAP
Dec 31, 2012
2,920
1,032
Safety switches have a tendency to stick when could particularly if a small amount of moisture has gotten into them. Some of the lawn mower tractor safety switches that are built into the seat cushion, will not engage when really cold because the foam is to stiff to push the switch.
Mountain Hill
L3800, LA524 FEL, Woods BSS 65 Box Scrapper, Woods RB 84 rear blade, trygg chain
Apr 5, 2013
12
Halifax,Nova Scotia
I've been having the same problem with my L3800, tractor starts no problem, Shut it off for a few minutes and it won't start. It has gotten worse with the sub 0 weather. Apparently it's one of the safety shut off switches, seat , Pto , according to my Kubota Service Dept. It's a pain, cause you don't want to shut off the machine, for fear of no re-start, for a few or many minutes. It's does eventually start, but it's a crap shoot! I'm going to look at and do some maintenance to switches.
4,011
We use to use what we called a Low Impedance Shunt when checking out safety switches underground,, just sayin
