can someone tell me what this part is?
Jckruid
M4500DT
Oct 24, 2015
20
Leavenworth, KS
This came off of an early 80's Kubota M4500DT. It was attached to the firewall. Lately every time I would start it smoke would come from the wires attached to this part. Now the tractor won't start and this part gets real hot and smokes. Obviously the wiring was in bad shape and was causing the smoke. Can anyone tell me what this is and what function it serves? I cracked it trying to replace the jumper wire on it and Unfortunately I can't get the wire off. There are no electrical parts inside this piece. Only what you see on top. There was one wire attached to the empty posts on either end. Couldn't i just simply wire these two directly together? This appears to only be a jumper between two wires. I don't get the purpose of this. Any help is greatly appreciated! Thank you
Jckruid
M4500DT
Oct 24, 2015
20
Leavenworth, KS
I assume at one point there was a fuse between the jumper. That is the only purpose I can see for this part. Thanks for any help!
Wild and Free
B2150 HSD w/Case L340 fel 68" quicktach bkt, 60" jinma snowblower, box scraper
Oct 25, 2012
390
North Dakota
That is a fusible link. The wire is the fuse for the terminals on either side of it. It appears judging by the crimped on ends that Some one may have removed the fusible link wire and put a normal wire in it which will cause the issues you are having.
You could remove it and install a normal fuse holder of equal amperage rating.
But it sounds like you have a shorted wire issue somewhere causing the smoke from overheated wires.
Jckruid
M4500DT
Oct 24, 2015
20
Leavenworth, KS
Yes, the connections on the link are extremely corroded and is where the smoke was coming from. I think someone installed the direct jumper many moons ago without putting the fuse back in between. Any idea what size fuse I should use? It's a link between the ignition and the starter I believe. Thanks!
Jckruid
M4500DT
Oct 24, 2015
20
Leavenworth, KS
I just put the two wires together directly for the moment and she fired right up with no smoking. It's been this way for decades so I didn't think it would a problem temporarily. I just needed the nerve to try that.
6,565
Probably had loose or dirty connections causing the heat build up.
You could replace with a smaller wire to let it function as a fuse, but a fuse would be much safer and easier to maintain.
Wild and Free
Oct 25, 2012
390
North Dakota
Just splice in an inline fuse holder with a 30 amp fuse.
OBKubota
2014Gr2120,Gr2728Snowblower,Gck5GrassCatcher,agri-FabSpreader
Oct 21, 2014
205
Ontario
Might have come out of an old dodge
First thing I thought was it looked like a ballast resistor from my old 78 Monaco lol.
SDMauler
2009 BX2360TV60, RCK60B-23BX
Aug 8, 2014
82
Parker, SD
The fuse needs to be sized for the wire. If it's 14 gauge, no larger than 15 amps, 12 gauge, no larger than a 20 amp fuse, 10 gauge, no larger than 30 amp fuse, etc. Fuses are there to protect the wiring, not the device on the end of the wire. Conversely, the wire needs to be large enough to carry enough current to quickly blow the fuse in case the wire shorts, or the device it feeds draws too much current. The "toaster element syndrome" happens because the wire is undersized for the fuse.
Also, when designing electrical wiring and circuits, they should be designed to be loaded only to 80% of the maximum capacity (the fuse size) to allow for startup peaks in current.
Hope this helps all you sparkies out there.
4,012
Yeah I have found more than one 1,000,000 amp slow blow fuse in UG DC trolley systems too,, ( thats a piece of trolley wire hidden in a fuse block)
2,825
I would either clean it well and try to reuse - or as mentioned, replace with a new wire and fuse holder.
Tooljunkie
May 13, 2014
4,150
My old power wagon heater fuse melted right out of the fusebox. I spliced in a high quality blade type fuse holder and a buss 30 amp fuse. Never had a problem since.
If you choose to re-use terminal block the screws and terminals need to be clean and connections need to be tight. I would also use terminal grease.
CountryBumkin
Sep 27, 2015
568
Central FL
That won't work.
A fusible link is designed to let high current flow for a short time without burning out.
So a 30 Amp fuse would blow at 40 amps, but a fusible link rated for 30 Amps would let 40 amps pass for a short time (if the time is excessive, the link gets too hot and melts).
pendoreille
B2620, fel, RB1560, Piranha Tooth Bar
Jan 2, 2015
476
Newport, WA
put a penny in a burned out fuse trick! I may have a roll of fuse wire floating about the shop. If memory serves me it is pretty light but let me look. Would gladly drop a length in the mail. Puttering in shop today and will get back at you.
8,703
That won't work.
There are 30 amp inline fuses that are slow blow!
So it would work and probably the best repair method considering his original block is in such bad shape! ;)
CountryBumkin
Sep 27, 2015
568
Central FL
I have not seen any of these. I looked at the link provided above - those fuses where for 32VDC and above. The only slow blow "14V fuse" listed was a blade style and the "overcurrent time" before it burns out was only 0.5 sec.
Maybe there are slow-blow in-line fuses for 12v systems, just nothing I've come across before. But I've been out of the business for awhile too.
Tooljunkie
May 13, 2014
4,150
Mike, you are correct, no slow blow in the 12 automotive industry. Fusible links are commonplace. Get a 30 amp resettable circuit breaker. Then when it trips you have to reset.
