BX5450 Snowblower shear pins
jgvicke
Kubota BX2370 with FEL, MMM, Bagger, Tiller, and Snow Blower
Dec 12, 2015
25
North Brookfield, MA, USA
Hello everyone. I had a shear pin break on my snowblower impeller, and the shear pins that my Kubota dealer sold me are not the right ones!
If anyone has a BX5450, can you upload a picture of where the shear pin is for the impeller so I can see what the installed bolt is supposed to look like?
I have attached a pic of how mine currently looks, so if you could take the pic with a similar view, that would be great!
Thanks,
John Vickers
Grouse Feathers
Feb 16, 2015
1,022
11
Lovells, Mi
According to the Owners Manual, that should have come with the blower, the shear bolt for the fan is a 1/4" NC 1 1/4" gr 2 with a lock washer and nut. This is a standard bolt you can buy at a hardware. Grade 2 bolts are the standard bolts sold in the hardware and usually not identified as grade 2. The only problem is most hardware grade 2 bolts this size are threaded all the way up. They will work, but a partially threaded shank would be better.
lordulrich
BX 2370, 60 MMM, Loader, Front Mount Snow Blower, Landpride 3 pt blade, Tiller
Jul 28, 2016
82
SE Minnesota
I wonder if there is something wrong with the Kubota parts catalog. I had the same problem that I got a handful of each type of sheer bolt (after breaking a auger bolt right before Christmas). The augur bolts were the right ones but the fan bolts were too big, and I had to go back and get more, of course the only break on days when the dealer is closed.
KeithG
2000 Kubota B2710, Woods BH75 backhoe, LandPride York Rake, B2783 Snow Blower
Jan 1, 2016
129
Rindge, NH
I have the exact same flanges on my snowblower (i.e. B2783 63") and I have broken 3 grade 8 fully threaded bolts so far. In each case I can see why they failed due to the weight of the snow and me going to fast.
Now I do not know if you should be using the same grade 8 bolt but I do know before I investigated everything about shear bolts I could not complete my driveway even once when I used grade 2 bolts.
My recommendation would be to ask the dealer what grade bolt should be used and if they know what the tolerance is supposed to be for that bolt. As a quick guide here are some bolt details for a 1/4"(diam) x 1-1/4"(len):
Bolt .................................. Failure force (in lbs)
Grade 8 not threaded ............. 4,418
Grade 5 not threaded ............. 3,534
Grade 2 not threaded ............. 2,179
Grade 8 threaded ................... 3,177
Grade 5 threaded ................... 2,542
Grade 2 threaded ................... 1,567
Grouse Feathers
Feb 16, 2015
1,022
11
Lovells, Mi
I am surprised that you have the same shear bolts with 9" more snowblower and 4 more horsepower. With my BX5455 I have never had a shear pin break from only snow or ice it has always been a rock or tree branch. Even wet heavy snow that forces me to slow down to keep the engine speed up does not break shear pins. I have never put a torque wrench on a shear bolt, but for this type of flange shear bolt you want it tight to reduce shock loading and increase the friction between the flanges.
