Hello, searched but didn't find anything so posting.
We have a BX24 with 550 hours we purchased with 400 hours 4 or 5 years ago. We think it may have seen some abuse even with the low hours.
Since I've had it, it has occasionally slipped from 2WD to 4WD on its own and it has been getting worse. My original concern was damaging something by having it in 4WD and not intending it to be, making a tight turn, etc. Now I am more concerned about damaging the transmission and having an expensive rebuild.
Doing some light reading it appears there can be internal and external problems. For external the lever can be misadjusted or bent and rubbing on something and could cause it to pop in or out of 4x4. I checked - no issues here. Moving the lever with the machine off it feels like there is no or little detent keeping it in place. Checking the Messicks diagrams (https://www.messicks.com/ku/84755?sectionId=216444&diagramId=335102) it appears there is an externally removable bolt with a removable spring and dent ball. I am hoping against hope that it is just a spring that has lost its ability to resist compression but what I am concerned about here is that if I remove the bolt and spring, will the detent ball drop in to the transmission case? I have an extensive history of screwing myself over with these kinds of things and could totally see the ball dropping in to the case if I remove the spring that is pushing the ball against the 4x4 lever..
Thoughts? I had resigned myself to having a transmission rebuild / refresh by the dealer for $2-3k but if I can replace a $5 spring instead...
