BX2230 air cleaner bracket removal
Steve Jennings
BX2230
Oct 20, 2021
Joplin, MO
The air cleaner bracket on my BX2230 has snapped off just above where the throttle cable is. I have the cleaner off, the cable loose at the pin and one nut removed from the lower front side of the bracket. Do I need to remove the engine compartment cover to get to other bolts that are holding the bracket. I can’t see anything from above.
Steve Jennings
BX2230
Oct 20, 2021
Joplin, MO
Yes, you will need to remove the underhood cover.
Thanks Whitetiger,
I had no idea this broken bracket was so common until I started reading some of the posts. I guess I will try to get it welded and put it back on. I should have removed the underhood cover immediately. I about killed myself just getting the cotter pin out of the throttle assembly. Ha This is the biggest project I have undertaken. I am not terribly mechanical.
3,413
Thanks Whitetiger,
I would just add, that after several attempts to fix the bracket on my BX2200, I finally just bent the ends and used some rubber cut from a bicycle inner tube to pull the ends together.
No more broken brackets and all seems well after a few years. The rubber strips I used are getting old though, perhaps I should change them?
dlsmith
BX2230, LA211
Nov 15, 2018
1,369
1,066
Goshen, IN
The bracket on my 2230 broke also soon after I bought it. It had been welded before, though very poorly. I removed it, ground out the old weld, V-eed out the area and MIG welded it back together. So far, after almost 200 hours it is still holding.
One thing that I believe will greatly reduce stress on the bracket is to not let the engine run at a speed where it shakes considerably, like below 1500 rpm. Those little three cylinder engines are great, but at low speeds do shake a lot, and the poor design of the air filter bracket can't endure it for long before it cracks and fails. A poor design by Kubota, but can be accommodated by watching the engine speed.
3,413
Here is what I did:
Still working perfectly today.
Grandad4
Apr 5, 2016
450
197
Greensboro, NC
Been there, done that... welding only gives a temporary fix... it will fail again due to vibration. Needs some kind of shock mount: rubber, soft plastic, etc. I rigged up something with a couple rubber strips from an inner tube that damped the shaking, worked great.
Tractor Gal
BX23D MLB
Oct 30, 2020
628
278
NC
Ditto to above comments about continued breaking of this bracket. At an earlier time when I was trying to get my little sweetie to tip top shape, I noticed the broken bracket, bought a new one...wasn't long until it, too, broke. Rigging up some kind of expandable strip as Henro did is the best idea. After the second one broke, I didn't worry about it anymore! So, it rattles. I need to get over it. :) It does not appear that it affects anything other than nerves.
Tractor Gal
