These tractors tend to have the boots missing on the drive shaft from the motor to the hydrostatic transmission which is also the same shaft with the fan for cooling the hydrostatic system when the boots are missing often the joint on both ends where the what time is it in are worn out as well I replace them it's about up $350 operation also you need to check the steering cylinder up front the older design 10 of the leak the newer cylinder for the steering system was a little over $200 about 3 years ago also you need to smell the radiator carefully and make sure it doesn't have a diesel smell these tractors tend to run a little hot sometimes a head gasket is bad or the or the head is cracked if they've been abused and run hot
