I was using my tractor yesterday just fine, then today out of the blue it won't start properly.
I turned the ignition to the on position, there was the typical clicking sound as expected. I turned the key slightly more to warm the glow plugs which went as expected. Then when I turned the key to start the tractor, it turned over a single time and I lost all power. I found that the 30 amp slow burn fuse blew.
I went out and bought a new one thinking it was a fluke, but after trying to start again, it turned over once and blew the fuse.
So far I've tested the battery which looks to be fine. I cleaned the connections as well. I'm assuming it's a short somewhere along the bw wire that travels through the two safety switches, ending at the starter. Is there a way to determine if the ignition switch itself is the problem? If it's a short somewhere along this path, how can I trace it down?
I picked up a multimeter but I only get power on the R cable which makes sense since it powers the other connectors in the switch (I think?)
Side note... this is my first post. Hello!
