bx 2230 won't shut off
dyenor
morenci,mi
my bx 2230 won't shut off I disconnected the battery then the ignition.
I pulled each one of the fuses still no good.
Finally shut off fuel.
I reconnected battery restarted ok but still wouldn't shut off
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,110
112
Hardisty, Alberta
Kubota BX series use a stop solinoid that gets energized to pull the fuel rack back which stops the engine. It is energized for a short time when you shut off the key then returns to relaxed position. Disconnect the wire at the solinoid ( right above fuel injection pump) and test to see if there is power there when you turn the key off.
Ed
eserv
May 27, 2009
2,110
112
Hardisty, Alberta
If there is power there then the solinoid is faulty ( or not adjusted properly if it IS moving). If there is no power there then take it to a dealer to have it repaired. You are then venturing into the safety interlock system and I will not advise anyone in repairing it themselves! I don't want anyone to run over their kids!
ed
dyenor
morenci,mi
Went to a dealer he let me look at his shop manual.
Looked that it may have been a blown fuse and it was.
The fuse was a 20 amp labeled acc lights.I would think this would be a safety concern with Kubota as it bypassed all safety features.But oh well it was a cheap fix
