Brush hog height
JRS
39
49
Central Texas
As I wait for my MX 6000 to arrive I have some thoughts and questions.
I will be mowing rough pastures. Can I mow with the mower elevated on the 3 point hitch or does it have to be lowered and supported by the tail wheel?
jyoutz
Jan 14, 2019
2,458
1,565
Edgewood, New Mexico
It should be lowered and supported by the tail wheel. Cutters throw stuff everywhere.
Goz63
Kubota L2501, LA525 loader, QH15,Land Pride RCR1860, BB2560, SGC0660, forks
Jun 19, 2021
299
349
Mississippi
You can mow with it elevated just be careful as stuff can fly out. I wouldn’t do a whole pasture that way. You can adjust the tail wheel to support the deck at higher levels. That is the safest route.
2,105
you ought to be able to move the tail wheel up and down with a couple of bolts/nuts being moved to get the height you want - and allowing the wheel to support the deck.
BigG
Sep 14, 2018
1,950
774
West Central,FL
Read your owners manual until you understand it.
You should be able to set the tail wheel so it will cut pretty high. Then drop the 3 point down about an inch lower. If you have a slip clutch make sure you slip it before you start. There are several youtubes on how to slip the clutch. If you have a shear pin buy the tools you need to change the bolt and some extra shear bolts and carry them on the tractor.
Go slow and start on the level parts of your field until you get some practice. Use caution when crossing ditches or going from flat to steep inclines so that you do not bind up the top link and bend it.
977
You can basically remove the top link if you don’t need to lift the mower.
Most newer mowers have a linkage at the top link so you can get plenty of slack to avoid damaging the top link or tractor.
2,947
Exactly. In fact, this is what I did for 15 years with my little 9N Ford shredding/mowing 20 acres with a Rhino 72” cutter that weighed so much the little Ford 3pt couldn’t even pick it up. I removed the top link and used it as a pull-behind mower on its tailwheel, gauging the cutting height with the 3 pt lift arms.
