Block heater question
Gb540
21
Central US
Would anyone know what style block heater part #70000-91500 is?
I.e. if it's threaded, frost plug tap-in, frost plug expanding tabs, etc.?
Not seeing pictures of this anywhere, and would be helpful to know before ordering.
19thSF
B2650, loader, MMM, pallet forks, tooth bar, rear blade, JD 318 w/plow, JD X350
Mar 1, 2020
347
87
Glendale, Rhode Island
I believe that you will have to remove a "freeze plug" and then press the fitting into the block. Take a look at the attached video. It may not reference your particular tractor but I believe that it will show you what has to be done.
Well maybe "not so fast". I couldn't find a picture of the part you specified either. What model tractor are you working with?
19thSF
Mar 1, 2020
347
87
Good morning DustyRusty. I did get that far, but the OP's question is still left unanswered. The OP is going to have to let us know what model number they are installing the heater in. As far as I can see, there are no pictures of the part on the web.
