Belly Mower RC48-62H Pulleys
Chaz Sliger
Kubota B2301 + Loader + Mid-Mount Mower
May 28, 2014
Portland, OR
Trying to replace the pulleys. They're pretty rough and eat up the belt.
Can't remove the retaining nut because turning it just loosens the blade.
I've never seen blades attached this way where there was no locking mechanism like a channel they fit into or a keyed shaft they fit on.
Once the blade bolt is loose there is nothing to torque against to remove the pulley retaining nut.
Am I missing something here?
-chaz
kubotasam
Apr 26, 2010
1,208
131
Alfred Maine
I am thinking a strap wrench around the pulley then use an impact wrench to remove the nut on the top. Do you have this mower mounted on your B7100? I just purchased one to put on my B7100 hst. Wondering how much you needed to change the mounting brackets.
Chaz Sliger
May 28, 2014
Portland, OR
Hadn't thought of using the impact wrench. I'll give that a go.
My tractor is a B7100HST-D and I got it used with the deck attached.
Doesn't look like the mounting hardware was changed.
I took the hardware off that connected it to the 3-point hitch for raising to make it easier to work on. I just leave it raised on those rear hanger links. It cuts close enough for my purposes like that. I switch out the clevis pins and replaced them with bent hitch pins that are much easier to work with.
Chaz Sliger
May 28, 2014
Portland, OR
Tried the impact wrench after re-installing the blade and torquing it down using just the blade as a stop agains a 2x4.
Worked Great!
Thanks for kicking my brain into gear.
-chaz
