Back Blade drops
Jofi
Tractor
Jul 19, 2019
Fairfield Vermont USA
I have a Kubota B8200 HST and while using the Front end loader the back blade will slam on the ground. I'm a little concerned that there is something going on with the Hydraulics.
shootem604
Apr 23, 2018
875
British Columbia
Check fluid levels. Check suction return hose for leaks. Is there an adjustment knob for the 3 point hitch ( in front/under the seat?
Tx Jim
M7040 HDC-1,JD 4255,Ford 6700
Apr 30, 2013
1,179
117
Coyote Flats,Texas
Sounds as if 3 pt control valve is leaking & when pump pressure is diverted to FEL control valve 3 pt has no pressure oil to hold 3 pt in raised position
