Rob
B6000DT / B7100DP /B8200DT/L225/Globe PTO Chipper/Lewis Backhoe/huxley TR66
quick question guys regarding the hydraulic connection block on a B8200 (non-hst)
what is the purpose of the "N" (neutral) port .
in previous projects the n port has not been on the tractors to hook upto, but the 8200 manual states using all three ports , and my new hyd valve also has the 3 ports.
From my understanding the my new spool valve is open centre so fluid will flow around when the spool in unused, why the n port then.
if i want to add a pair of q/r ports for my log splitter separate from my new spool which works my top link & trailer i assume i will just carry the flow from the "T" port on my new valve to a diverter valve , with a pair of lines to the splitter and line then to tank.
Sorry if this sounds a bit basic but i have done this before but cant remember which way round i did it.
pic of the 8200 valve block.
rob
rob
