B7800 dies, depress brake, comes back up
3forks
B7800 2003
Jun 26, 2022
PNW
2003 B7800. I’ve had it for 10 years no real issues other than seat safety switch.
It has taken to randomly dying. Generally turns right back on. Found that if I depress the brake, it will generally keep it from dying. But now I can’t get it to start, turns over fine.
Found the fuel filter had dislodged, cleaned it some but no success. It does need replacing.
Mechanically ungifted.
Thanks for your time
8,703
When it's dying does it smoke?
When it's dying does it die instantly or slowly die?
3forks
B7800 2003
Jun 26, 2022
PNW
Maybe a whisp of smoke, very pronounced and generally not there.
Dies in about 2 seconds unless I catch it with the brake pedal. If I just let off HST pedal it still does, need to depress the brake.
Thanks
3forks
B7800 2003
Jun 26, 2022
PNW
Thanks
should have read NOT very pronounced smoke.
8,703
That quick of dying is indicative of an electric issue.
Sounds like wiring or HST switch issue.
Inspect any wiring that pressing the brake pedal could effect.
3forks
B7800 2003
Jun 26, 2022
PNW
Checked battery and it should be good. Got the corrosion off and tried starting it then. Now it won’t turn over and screen goes blank after trying to start.
I don’t think it’s related and lean on a fuel issue for original problem. I think I’m going to need a professional at this point.
Thanks all for your time.
8,703
Bad main battery cables or connections, take off both sides and inspect and clean, look for swollen parts in the insulation on the cables.
It's not a fuel issue mainly because it does it suddenly.
