B7100 3ph spool valve binding
torch
Jun 10, 2016
2,593
836
Muskoka, Ont.
I just got back in from blowing off the ice rink. The 3ph spool valve has suddenly started binding occasionally at random times, usually in the neutral position. Sometimes when trying to lift the blower, other times when trying to lower it. It might be normal 10 or 20 times in a row, then suddenly stick for no apparent reason.
Normally, the lever is a very light, smooth transition. But when it sticks, it really sticks. I checked to see if the stop rod was jamming, but that seems loose in the stops even when the control is stuck. This feels like something is occasionally binding internally.
Any ideas?
2,233
Sounds like ice. Can you hit it with a heat gun when it sticks?
torch
Jun 10, 2016
2,593
836
Muskoka, Ont.
No sign of ice externally and the valve is inside my cab. Temperature has warmed up to above freezing and I have been working the fluid for a couple of hours, so I doubt anything is freezing internally. Fluid looks good -- completely clear, no signs of dirt or contamination. Using Amsoil synthetic HST fluid.
2,233
Then it must be a loose piece of crud (piece of rust, o-ring?) that is inside floating around where it can jam the spool. Sounds like a dis-assembly & clean may be in your future.
SidecarFlip
Banned
546
Failed sealing ring cocking in between the bore and spool?
torch
Jun 10, 2016
2,593
836
Muskoka, Ont.
That's what I was starting to think. However, looking at the parts diagram, I don't see any o-rings or seals on the spool.
There's a spring-loaded ball detent mechanism. Looks like that all rides in an oil bath.
<sigh> I think Lil foot is probably right -- there's a disassembly in my future. I wish these things wouldn't happen in winter...
SidecarFlip
Banned
546
When I bought the M9 years ago, I had an issue with it developing oil pressure. It wasn't building pressure fast enough to satisfy the oil shut down switch and the motor would shut off. Turned out it was a spool valve in the front of the engine that had a burr on it. dealer replace the valve and the entire front cover under warranty.
I know, what does that have to do with your issue... You may have a burr on the spool that is hanging it up, possibly. I was going to mention that in previous post but forgot. Could have a piece of flaked off hose in there as well. I've had that issue in the past too.
2,233
I have a B219 FEL with a Cessna valve on mine. When I got it, it would occasionally stick in the float position. It kept getting worse until it locked. Dis-assembly showed that whole detent mechanism has rusted away to junk. Parts were no longer available , and I haven't had time to make new parts, so I just left it out, and hold it in float by hand. The mechanism on mine is not oil bath, so a little water was all it took to destroy it.
Pic shows where the detent setup is located on mine.
