B3200hsd hydraulic fluid dipstick and fill hole?
Salmonhound
B3200hsd
May 21, 2022
Hello,
I just purchased a used b3200hsd. Can you confirm this is the hydraulic fluid dipstick and fill hole by the back pto?
Also what type of hydraulic fluid/wt/type etc does everyone recommend?
I dont have a printer here or I would print out the manual. Will need to do that at a later time. Everything else seems good. If this is the dipstick for the hydraulic oil it will need some added. What is in there looks clean.
Edke6bnl
B7800 Kubota, case 1840 Skidsteer Ford 3500
Mar 31, 2022
259
144
Agua Dulce, California
Thats the fill and check stick. I personally am using hydraulic/transmission fluid combo fluid. But others will only use kubota's fluid.
