I have a B3200 that has a BH-76 backhoe sub-frame and rear power beyond ports for the backhoe installed. The backhoe is not normally installed on the tractor, and I want to add 2 rear remotes for use with 3 point implements. Since the backhoe and 3 point implements can’t be installed at the same time, could I just run the feed line and return to tank for the backhoe power beyond (which are normally looped) to in and out power beyond lines on rear remotes valve block that I get to provide flow to the rear remotes? Right now it looks like the power beyond port on my block runs to the backhoe power beyond fist, then runs to the loader valve. When the backhoe is not installed, the power beyond ports are just plugged into one another, making the loader valve the only thing in the PB loop. If I feed the rear remotes from the PB connectors, that wood put the rear remotes first, and the loader valve second. Is that a problem? I don’t think I would ever be using the rear remotes and the loader at the same time.
I also want to add a 3rd function to my LA 504 Loader. Does flow for the third function valve have to be added to the power beyond loop, or is there a port on the B3200’s loader valve that can provide flow to the 3rd function.
Sorry for all the questions. I have searched and tried to find the information I need, but I can’t find info on a B3200 with a backhoe power beyond, rear remotes and a loader and with a third function. Below is the diagram of how my rear power beyond ports were plumbed when installed by the dealer.
