B3200 HST Pedal Sticking
MattN03
2011 B3200, LA504 FEL w/B2366 SSQA conversion, BH76 BH, EA Wicked 55
Sep 5, 2016
222
40
KY
My B3200 HST pedal sticks occasionally/randomly. When I press down to go forward, there is resistance, and the pedal won't move forward. I can push down to go to reverse, and that will work, and then the pedal will allow me to move forward again. The pedal grease fittings are kept greased, the tractor is clean underneath, and I don't see any obvious physical obstructions. Could the pedal damper be sticking? Messick's has them for $200 so I want to be as sure as I can before I throw $200 at it, and I'm not overlooking anything. Tractor has about 660 hours on it.
2,167
Have you climbed under and looked at the linkage ? ( with tractor off! )
If greased - then something is causing a bind going forward. I do not think it is hydraulically linked.
MattN03
Sep 5, 2016
222
40
KY
I have rolled on a creeper underneath and didn't see any linkage binding. That's why I was thinking it was the pedal damper?
Dieseldonato
Mar 15, 2022
728
437
Pa
Disconnect the damper and see how the pedal feels without it. It would be the most likely imo
crbr
2006 B7800, 2022 BX1880
Jan 8, 2010
TN
Solution yet?
