Short version is that my B3030 (no cab) position lever (to raise/lower the three point hitch) will not stay up. I got it about 2007 or so and it worked fine. With the finishing mower (or box blade) on the back I could raise it off the ground (slightly or all the way) and it would stay up as until I pushed the lever back down. Several years ago the three point hitch just stopped staying up. Even sitting still, if you pulled the lever to raise the implement, you could watch the lever move forward until the implement was on the ground. This past weekend I had to to access the Neutral Hold (replaced a bearing on the neutral arm) and tried to look at the hydraulics that the position control lever was attached to. I am not mechanic but I did not see anything that might be the cause of the three point hitch not staying up. I have changed all the fluids often. I do not how a front end loader or a belly mower, only the implements for the three point hitch on the rear. I have replaced the safety switches under the seat, on top of the transmission. Could I have somehow done something wrong when I replaced the one on top of the transmission. It does not seem likely but who knows. Thanks for your help.
