Started having trouble engaging my PTO the lever turning it on and off works ok but when i try to move from mid to rear the mid doesn't want to disengage all the way and when i try to move back to the mid i get a grinding noise sometimes, if i move it rearward real abrupt it will engage but the slightest movement to the mid disengages it , it like my linkage has moved or something or both are trying to engage at the same time but i don't see anything loose, i primarily use tractor to mow with, with occasional three point fertilizer spreader.
