Want to add a HTL to my B2601 for box blade usage after I remove my BH70 backhoe. What is required to allow the addition and use of the HTL? Was thinking of the Holland HTL SPH320033 but what else is required? Thank you
My B2601 did not have a BH but I used Kubota rear dual valve set with T&T from FitRite hydraulics. I wouldnt use a tractor without rear T&T, entirely different output on finish. Brian's custom link fabrication is perfected, unbox and install.
FitRite makes what looks to be an excellent product from a fit and finish standpoint. I would have ordered if it wasn't for the wait due to popularity.
If you are in a hurry, and don't mind putting in some sweat equity, check this thread out - if you measure the dimensions of your top link bracket at the tractor and your current top link range, I can tell you if the Cat 1 link I purchased will fit.
I just got a hydraulic top link from Spare parts Holland https://sparepartsholland.com/product/hydraulic-top-link-cat-1-1-with-locking-block-460-670-mm-with-2-x-hose/ It's also available on Amazon and on E-bay took about 4 days to arrive. For just a few buck more and without any risk of the fees...
