B2400 HST bi-steer turn problems
borot
ireland
Hey guys,
I'm a new member from ireland and in bother with my kubota B2400 HST. The bi-steer turn has stopped working. does anybody know where the problem could be?
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,101
Hardisty, Alberta
The most common problem with these bi-speed turns is the activation cable breaking or stretching . It should pull the lever on the front axle fully when engaged, if not you either replace the broken cable or adjust it. If the cable isn't the problem you'll have to take it apart, something has failed inside ( clutch pack, spring, shift fork etc.)
Ed
borot
ireland
ed, thanks very much. i'm all over it the weekend! and will report back monday......................
