B2320 Bogs Down Uphill in High HST
BowerBota
2015 B2320 FEL, 60" MMM, 48" Rear Blade, BXpanded sprayer, 4' Brush Hog
Aug 23, 2015
Shenandoah Valley, VA
Hey Bota Brothers!
I have a B2320 I purchased brand new with the HST. I was attempting to go uphill in high gear and it bogged the end down greatly and it acted like it was beside itself to get uphill, but when I switched it to mid gear, it would progress as it should.
The hill is a gradual slope and my BX would go up in high easily.
Is there something wrong or is the High gear not meant for that kind of incline.
Thank you for your help. I am going to be posting pictures of some mods that I have completed too.
Tooljunkie
May 13, 2014
4,150
Its a pressure volume thing, instead of pressing pedal down more when going up a hill, try going slower. More speed means higher flow equals less pressure. So under load or up a hill slower may keep you moving. Ultimately you will be doin less harm to machine by gearing down.
6,810
TJ nailed it.
Your BX had a 2-range HST, and the B is 3-range. I would guess high range on your B should only be used for high-speed road/trail travel. Use the mid-range for those places you could get by in high with the BX, but are steeper, etc.
BowerBota
Aug 23, 2015
10-4, I kind of thought that, but I def. wanna make sure that was the case and not something wrong. Thank you all.
ShaunRH
L3200
May 14, 2014
1,414
Atascadero, CA
Easy to confuse that pedal with a throttle pedal isn't it?! I like to think of it as a variable gear selector. You still have a throttle there too.
