axle pivot bushing
Arkansas Dave
L185, Frontier GM1060R finish mower, 4ft box blade,middle buster, behlen blade
Jul 12, 2021
47
17
Arkansas
I was wondering if anyone knew if my L185 had a front axle pivot bushing grease zerk? I can't
find one and was wondering if it had one I am going to look in the manual and see what I
can find just thought someone might know off the top their head.
thanks
Dave
3,031
If you go to Messicks website and look at their parts diagrams you can find the answer to your question. I do not see any “fittings, grease, nipple” on the L185DT (4-wheel drive model) but there are FOUR grease nipples on the 2-wheel drive front axle, one just on the top/side of the axle support/pivot, one at each spindle, and one at the front pivot.
Arkansas Dave
Jul 12, 2021
47
17
Arkansas
Thanks I tried to find it in my diagram I had and on the machine but didn't find any. I
did grease the steering pivots and spindles. i will look in those
areas thanks for the info
Dave
1,001
On my L185F there is one fitting on the front axle pivot at the center of the tractor. It is nearly impossible to see and I recall not on the side it is supposed to be on.
If you look there should be a plate about 3/8 to 1/2 inch thick that attaches the pivot point to the tractor. There is a curve in that plate that looks about big enough to get a grease gun into and if you shine a flash light you should see the grease fitting about 2 inches back in that groove. Mine is on the left side (side starter is on) but there is a similar curve on both sides.
I believe the DT is the same as the F
Arkansas Dave
Jul 12, 2021
47
17
Arkansas
Dave
found it finally thanks I appreciate the help
Dave
