Auxiliary Rear Hydraulics
chasdg
Front Loader, Grader Blade, Woods BH 90-X Backhoe, Wood Splitter, Flail Mower
Jul 30, 2016
Chilmark, Ma.
I have on my Kubota rear hydraulics which is used for the Woods backhoe mostly but also for a wood splitter. A problem I have noticed when not in use there is what I would describe as a hydraulic hammer as you get in water pipes when you shut a valve too quickly and I believe it contributes to hoses not lasting too long. I know the open center valve when you disconnect the backhoe you need to route the hose back correctly or the front loader will not operate. So what causes that shock and is there a way to stop it?
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
3,788
296
Williamstown Ontario Canada
Are you doing this backhoe removal hose change with the machine running?
Dave
mikester
M59 TLB
Oct 21, 2017
896
167
www.divergentstuff.ca
You can reduce shock adding an accumulator. I don't see the kind of problems you are describing.
Did you crank up the system pressure to give you more lift? Get a pressure gauge and test your system against spec.
chasdg
Jul 30, 2016
Chilmark, Ma.
Dave
I definitely would not want to try that but thanks I believe I have solved the problem, chasdg
I will check the pressure but I believe most of the problems are due to Mice the hose I took off had chew marks where it ruptured. To make matters worse I had the old hose in a plastic bag in my pickup to go to NAPA and the F)*&^%g mouse chewed the bag and let all the mess end up on the floor of my pickup.
