D D2Cat Well-known member Lifetime Member Equipment L305DT, B7100HST, TG1860, TG1860D, L4240 Mar 27, 2014 12,980 4,364 113 40 miles south of Kansas City May 8, 2022 #1 Always best to check battery good under load first. Then connections at battery. Then connections at the other end of the battery cables. All connections need to be clean, no rust or paint. This is the result of failing connections. Reactions: 3 users
85Hokie Moderator Staff member Lifetime Member Equipment BX-25D ,PTB. Under Armor, '90&'92-B7100HST's, '06 BX1850 FEL Jul 13, 2013 10,332 2,157 113 Bedford - VA May 8, 2022 #2 perfect description of ohm's law ! I actually use a similar picture to explain in the classroom.
