Anyone ever heard of "Value Leader" backhoe?
drchris1978
Kubota BX1870 for mowing & bagging and plowing snow
Feb 13, 2018
17
Dartmouth, MA
I was messing around online and came across Value Leader VL-BHM5 backhoe. The website says it fit 18+ HP sub-compact tractors and mounts to CAT 1, 3 point hitch. Anyone ever heard of this brand? Is it cheap Chinese junk? Is it safe to run an aftermarket backhoe on a 3 point hitch? I know my BX1870 doesn't have a backhoe option from Kubota. I read some posts where people say the weight of the backhoe can stress your 3 point hitch & frame. I'd only use it for digging small holes/trenches for conduit, probably a few times a year. This is where I found it. http://www.value-leader.com/5-dig-s...oe-w-tank-pump-filter-cat-i-18-24-hp-vl-bhm5/
Any advise?
5,158
three point mounted BH are sketchy in my opinion. I wouldn't do it. That unit says it weighs 750 lbs plus. Kubota BH's for the BX series are somewhere in the 600 lb range and the 4 point mounts/subframe are much more durable.
There are many other viable options for trenching for conduit. I'd suggest renting something rather than buying a 3 pt mounted "value-leader" BH.
drchris1978
Feb 13, 2018
17
Dartmouth, MA
I only ask because most backhoe's attach directly to the frame, not the 3 point hitch. I've read posts where folks said to stay away from heavy implements on a BX 3 point hitch.
5,158
