Hi. I have a B2650 that I'm adding a valve to. The valve is a monoblock valve which requires a tank return. The only port I know for sure is a tank port is the one connecting the loader valve to the tank. My plan as of now is to add a manifold to this line and connect the loader valve and the new valve to this manifold. NOTE - I'm planning to get a manifold with extra ports for future projects.
Before I commit to this, figured I should ask... Does anyone know if the B2650 has any other (currently unused) tank ports I could tap into?
Also, since I'm new to hydraulics, the return lines aren't handling much pressure, right? The factory line from the loader valve to the tank is just barbs and hose clamps.
Thanks!
Thanks!
