Advise on replacing L3301 HST oil cooler line (inlet)
tcpkubota
L3301 HST, Land Pride 6' Finish Mower, Kubota ZD 1211 Zero Turn, Kubota KX057-5
Sep 28, 2015
Union City, TN
I have a small leak on the oil cooler line on my L3301 tractor. the leak appears to be coming from around the hose clamp directly behind the power steering shaft . I tightened the clamp but that did not stop the small drip leak. I know I will need to remove the battery to access the lines going to the cooler. Any advice on how best to change the line. Do I need to change both? Are there any "tricks" or helpful advice to get this job taken care of?? Many thanks for any advice.
Nicksacco
Kubota L35 TLB, 2014 RTV-1140CPX
Sep 15, 2021
767
504
Bahama, NC
Did you figure it out yet or do you still need some help?
You are referring to this - see diagram
7,309
FWIW. one oil cooler line on my L3901 leaked right out of the box. Tightening the clamp fixed it. Removing the battery to access it was trivial.
Oil cooler hose leaks seem to he a common issue in those models.
