Added weight makes a big difference (PICS)
Delmar
G1900 / Kubota BX
Sep 24, 2015
180
Bluegrass State
I use a G1900S to mow a sloped lot. I've learned to lean and slow down in a couple of dangerous areas and much prefer the mowing experience over my BX1860 (although I wish the G1900 had 4WD or differential lock).
I picked up a rear end weight made for a different Kubota machine. I didn't weigh it but think it's around 35lbs. Did a little fabrication to mount it on my machine and was surprised what a difference it makes!
20160923_203954 by Jeff Metcalf, on Flickr
20161006_094240 by Jeff Metcalf, on Flickr
I also changed tires to ones with a bit more aggressive tread, but I think the weight is mostly responsible for the positive result. It's low and right at the rear axle.
I've had no slippage at all, even in one area in particular where I frequently "slide," especially if the grass is wet. I've mowed early a couple of days just to see how the mower does under bad/slick conditions and it's been fine.
So, if you experience slipping or sliding, even a modest amount of weight can make a big difference.
armylifer
Mar 26, 2013
2,144
914
Thurston County, WA
I experienced the same result by adding weight to the rear of my BX1860. Adding weight to my tractor makes the the tractor more stable when mowing on a slope. An added benefit is that I don't need to use 4WD when mowing anymore.
alansz400
B7500. FEL, Piranha tooth bar, box scraper, post hole digger, 3 pt. bucket
Oct 26, 2013
265
Loudonville OHIO
I put a set of wheel weights on my sears lawn tractor that I mow with and the hill in front of my house that I trouble mowing all summer is now no problem. Much better traction and the rear wheels stay on the ground much better. Amazing how a little weight on the wheels can make such a big difference.
zin01
52
Royse City
So your saying that if I keep being lazy and using the tractor therefore getting fatter the "added weight" is a good thing.. I'll see if that will fly with the wife lol
armylifer
Mar 26, 2013
2,144
914
Thurston County, WA
No, what I am saying is that you should add at least a 6 pack per 2 acres that you mow. That will be just about right.:D
