A few more questions about my ZEN NOH ZL1501DT
Dog Trot Acres
ZEN-NOH ZL1501DT with a 1846QT BUSH HOG frontend loader, 4 ft BUSH HOG
Jun 29, 2018
10
Millbrook, Alabama, USA
First, I am interested to find out the year of my tractor. Did they make this tractor model for more than one year? Is there any significance to the Z in the ZL1501DT? Below is some info I have collected from this site. Does most of this seem correct? Mine is a 4wd. Thanks again. Great information here. Keep up the good work. I will post pics soon.
ZEN NOH ZL1501DT
Kubota Z751 engine
Oil filter -
KUBOTA 15108-32080
NAPA 7030
BALDWIN N/A
WIX 57030
FRAM N/A
Air filter -
KUBOTA 70000-11221
NAPA 6270 BALDWIN PA1865-FN
WIX 46270
FRAM CAK530
Fuel filter -
KUBOTA 15221-43170
NAPA 3390
BALDWIN BF7683
WIX 33389
FRAM P7514
Cooling: 5.6 quarts
Engine Crankcase:4.0 quarts
Engine oil DS (CD)
>77*f - SAE 30
77*f to 32*f - SAE 20
<32*f - SArE10W, 10W-30
Steering Box: 0.3 quarts
Gear Oil SAE 80
Transmission:
(L185/L1501) 23 quarts
(L185DT/L1501DT) 24 quarts
Gear Oil SAE 80
(DT) Front Axle Diff. Case (right/left): 1.1 quarts
Gear Oil SAE 90
(DT) Front Axle Gear Case (right/left): 0.8 quarts
Gear Oil SAE 90
Engine Detail:
Kubota Z751
diesel
2-cylinder
liquid-cooled
45.3 ci [0.7 L]*
Bore/Stroke: 2.99x3.23 inches [76 x 82 mm]*
Power: 17 hp [12.7 kW]*
Rated RPM: 2800
Titus Caird
Zen-Noh L1501DT
Oct 6, 2020
Ca
Thank you for this, it was super helpful. I was able to use a FRAM PH3600 oil filter.
