7040,Button halfway down loader control arm????
GWD
M7040, L48 TLB, BX2200
Jan 8, 2010
792
17
Northern California
What does it do? Just got the tractor and have it in the warm shop but can't seem to figure it out. It isn't the ones that run the grapple it is farther down the lever.:confused:
Are you referring to the metal tab that comes out of the plastic housing?
A photo would be a GREAT help.
hodge
Nov 19, 2010
2,960
537
Love, VA
Welcome to OTT, Rooster!
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,255
1,055
Williamstown Ontario Canada
The attached pages from a Kubota loader manual should help.
Unless you have the self leveling loader, one which keeps the bucket bottom horizontal as you raise the arms, the control you are referring to is likely the one to lock the control and avoid the loader moving such as accidentally lowering when you are driving down the road.
Dave M7040
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,187
170
Hardisty, Alberta
It turns the power on or off to the live third function (grapple)
rooster
MFWD 7040
Jan 2, 2013
Medicine Hat, Alberta, Canada
Hey guys thanks for the replies!!! I think eserv is talking about the same button. It isn't the one farther down that "locks" the handle from moving all together. It is about halfway down and is on a tab that is wellded to the shaft,so it wasn't added on later.
fast*st
M7040, L2900, F550 ford, Yanmar vio70 excavator, Case 580, JD 350 dozer, JD 644E
Jun 26, 2012
172
Northern Mass
Yep agree with eserv, its the white round button, moves up and down, located on the front end loader control stick. That is the power for the third valve function, down is on, up is off. safety lockout or somesuch.
fast*st
Jun 26, 2012
172
Northern Mass
It should light up when you push it down. The light will go off when you push on it again and it come up.
David
Mine must have a broke light! it looks like the light up kind! Maybe need a nice blue led
ovrszd
M9540
Oct 4, 2011
Missouri
They light up very faintly and unless you are in semi-darkness you can't see it.
The idea of the button is if you are using the loader without a third function attachment you should turn it off with the button. Purpose being so you don't accidently push the "up" or "down" button on the knob, which if activated would hydraulicly load the circuit unnecessarily.
Push the button once and it locks in the down position. Push it again and it locks in the up position. Down activates, up deactivates.
If you look at this picture, it's the white round button about halfway down the control lever. The two black buttons on the knob are the function up/down buttons.
urednecku
Kubota M7040, MF165, green hay equipment, & other old misc. equipment
Jan 3, 2013
central Florida
What ovrszd said. The light in mine went out a few months ago...about 800 hours on the machine.
When I shut down I've tried to make a habit of after the engine stops, turn the key on, then hit the on/off button, then the up & down buttons a couple times (to relieve any pressure that might be in that circuit), then back off. I don't like to leave any pressure in the hydraulic system when the tractor is shut down.
