3rd Function advice
aaluck
Oct 9, 2019
928
746
Snowdoun, AL
Looking to add a grapple to my L4400HST. Been watching videos and it SEEMS like a pretty simple process to add the unit. My questions are:
1. Is the addition as simple as moving two hoses around (plus wiring)?
2. Is there a 'best' unit you folks have found and ones that have given you problems?
Thanks
Creature Meadow
Sep 19, 2016
1,063
135
Central North Carolina
Take a look at Everything Attachments, I don't own one but I am a fan of their implements. I have 4 implements I bought from them and they are well built.
I'm not implying others are not good but watch some of the YouTube videos of hem testing implements and tours of their facility. I think you will be impressed.
Best of luck in your search.
Jay
bird dogger
Vendor Member
Feb 24, 2019
1,571
1,416
North Dakota
I take it you're asking about doing the 3rd function install yourself? It maybe isn't quite as simple as you laid it out, but you're not far off. Ha! I added a Summit 3rd function kit to my B2650 (as did a few others) and have pics and write up on OTT. It wasn't near as bad as some people make it out to be.
Have a clean place to work and lay out your parts/tools before hand so you have everything ready. Basically, there's 3 elements to the install. 1. mount the valve and cut into the Power Beyond hydraulic circuit. 2. Hookup and run the hoses to the loader cross tube or your mounting spot. 3. mount the controls and run the power to the unit.
Just make sure you keep things clean while cutting into the hydraulic system. Only during step 1 will your tractor be inoperable. the others can be done later. But if you have everything laid out and ready to go, there's no reason you can't do it in an easy day if not an afternoon.
JDP
L4701
Dec 15, 2020
24
11
Nebraska
I installed a Land Pride valve on my L4701 and it was very easy. The Instructions were great.
NHSleddog
B2650
Dec 19, 2019
2,149
1,823
Southern, NH
I have the OEM LP 3rd function and have had to replace the joystick twice now. The bottom switch crapped out both times.
I ended up buying the Summit joystick handle (it has micro switches) and retrofitting that to the LP.
Either kit tends to be easy in my view. I guess it would depend on your level of comfort.
bearskinner
Sep 1, 2014
925
238
N. Idaho
I have the land pride 3rd function set up. My local Kubota dealer offered it to me at a little under what I had seen for pricing, and free installation. It has worked great for 4 years now. I think I use the grapple more than any other implement.
aaluck
Oct 9, 2019
928
746
Snowdoun, AL
Do you have the link to that? I believe your set-up is a bit different than mine but might be helpful.
Petey Kubota
B2601 Kubota loader back hoe
Milford PA
Hello all I have seen it somewhere here looking for instructions on adding the summit third function valve plumbing with an existing OEM backhoe on my Kubota B2601. Summit does not have instructions for the actual plumbing for that. Does anyone have instructions for that.
Thank You
Elliott in GA
Mar 10, 2021
632
611
North Georgia
I have a WR Long 3rd function - a very popular choice. The Messick's video covers it well.
4,052
Be aware that there are TWO different versions of '3rd functions'.
One, a TRUE 3rd function allows full use of the other 2 functions in addition to the 3rd.
Two, a SWITCHED 3rd function, where you LOSE an existing function while the 3rd function is in use.
bird dogger
Vendor Member
Feb 24, 2019
1,571
1,416
North Dakota
Thank You
See the link in my post #8 above. I bought my B2650 with the BH77 and loader already installed. I added the Summit 3rd function kit myself and only had to make one minor mod to the kit to accommodate the backhoe. There's pics in that writeup. I'm guessing your B2601 setup would be very similar.
