360/70r20 pressure on M7060
bkandor
M7060 (new), B8200 (very old)
Jun 26, 2021
ontario
Hi,
Just took delivery of M7060, the front tires are 360/70r20. The manual doesn’t list this tire for pressure.
They came with about 22psi in them but they look way too soft to me (side wall flexing) when driving and using fel. The only reference I found show Max old at max pressure of 4300lbs at 35 psi.
What is a good pressure for this tire size?
thanks!
kubotafreak
Sep 20, 2018
1,022
374
Arkansas, US
Front tires are usually set close to max tire(as cast into the sidewall) rating on machines with loaders. The rear is dependent on load.
2,167
Pressure is a property based on application!
Obviously - FEL work will need more PSI than mower work.
And too much pressure makes for a rough ride.
I would say bump that up a bit - 25-27 and see how you like it
