2017 BX23S with 110 hours - ignore "hours" service interval and change fluids?
dje
BX23S
May 30, 2023
11
Vancouver Island, Canada
I recently bought a 2017 BX23S with only 110 hours on it. It had its one and only dealer service in 2018 (50 hours). If I were to follow the service manual strictly, then I wouldn't be changing any fluids until 200 hours (apart from coolant).
I didn't feel comfortable running old oil (could be 5 years old), so I went ahead and changed it (& engine oil filter). I also flushed and replaced the coolant and the engine air filter.
I'm wondering if I should go ahead and change anything else - namely, the hydraulic fluid (& filter), front axle oil fluid and fuel filters. My gut tells me I can probably follow the standard service intervals (based on hours) for these fluids/parts - but I'd appreciate some other viewpoints.
Thanks!
4,853
Yes you should change hydraulic fluid and filters too!
GrizBota
Apr 26, 2023
1,098
699
Oregon
I believe the operators manual provides time frames in mos/years (as well as usage hours) regardless of usage hours for some service aspects. You might check that.
Myself, when I get a used rig, I change out all the fluids pretty much regardless of what the (nearly always incomplete) service records show. That way I “know”the condition of all the fluids for certain shortly after I own it.
1,824
Edit: except automotive trans fluids...LOL
hodge
Nov 19, 2010
2,849
367
Love, VA
If it were me, I would first check the condition of the fluids. If they look good and clean, I would probably wait. I may change the filters, but if the fluids are good, there's no reason to change them. Changing good, clean oils makes no sense to me.
3,916
There are two 'camps' to the 'change the HST oil' debate...
Yes, it's a good idea to do all, so you KNOW when it was ALL done after that well....
....while changing HST oil on a regular basis may sound good when was the last time( if ever) you've changed the HST oil in your lawn mower or the automatic tranny in your car or truck ?
I KNOW the HST in the 25+ year old Cub Cadet(MTD ) rider, that I've used and abused has never been changed, and it still drives fine. A lot of newer riders don't even have drain plugs for the HST (JD for sure...). even some car trannies don't have them ( or dipsticks ?).
For the OP, for sure, remove the 'screen filter' ( behind left wheel..fun..) and clean. Course to do that , you need to drain the oil. If you're careful, you can reuse it.
The Evil Twin
L2501, LA526,
Jul 19, 2022
2,330
2,205
At 6 years old, I would change it. Everything degrades over time. How much? Who knows. But, I would change it now and then follow the schedule from there.
1,824
Good point Jay......I forgot that I am in the "If you don't completely flush your automotive tranny fluid with one of those flushing machines, and change the filter at 40k, then never touch it unless you absolutely have to" camp.
Although my observation is completely anecdotal, I have witnessed too many customers that have their tranny fluid changed at 80 or 95k, only to return 3 days later with shifting problems.
I'm not sure there is a 100% "apples to apples" thing going on, but you bring up a valid point.
I guess it's one of those whatever makes you feel better situations.
If I were the OP, I would change it since he is within the scheduled maintenance time frame and it would just make me feel better.
PaulR
Aug 3, 2020
580
456
Hadley, MA
2020 BX23S here with 109 hrs.
I've done oil, filter, HST filter change but no Hydraulic oil just yet.
I may do mine at 150, we'll see.
Of course, I think my rear PTO seal is leaking, so that may alter the schedule a bit.
TheMurf
BX1880.with loader and 48 inch deck. 1990 Gravel 12G Riding tractor.
Jun 25, 2022
146
66
Upstate New York
If it were mine, I change all the fluids and filters including the air filter and grease the tractor. I'd remove the deck, clean it, sharpen or replace the blades and grease it too.. It's your machine do what you feel is right for you.
4,001
Ev
"Everything degrades over time"?
The Kubota dealer told me that the 10 gallons of SUDT I bought, has an indefinite shelf life.
The Evil Twin
L2501, LA526,
Jul 19, 2022
2,330
2,205
Ev
They are incorrect.
Every major refiner states 5 years if unopened. Some list up to 10 years given controlled storage conditions.
Could it go beyond that? Sure, but how long? They are not going to say that the properties will not change beyond what they state.
Biker1mike
Jan 11, 2022
1,164
1,252
Gallatin, NY USA
I have never heard of a machine that had too much maintenance, but have heard of many the were under maintained.
For me, if in doubt change the fluids and filters, mark the hours and date.
Up front cost are a tad high. Pay me now or pay me later.
4,001
They are incorrect.
So....
If I store it for 4 years, and then use it?
I only get one more year, before it needs to be changed again?
I think "every major refiner" likes to take advantage of the paranoid consumer.
2,341
At the end of the day, I don’t believe I’ve ever heard of anybody claiming that changing fluids too frequently caused any kind of a problem. If it doesn’t break the bank, why not just do it? It might feel bad for your wallet, but certainly will feel good otherwise.
2,341
So....
I can’t help but think about hearing of people buying Kubota tractors and using them when they are 40 years or more older. And some of them are HST tractors I’m pretty sure. So I can relate to what fried1765 is stating…
The Evil Twin
L2501, LA526,
Jul 19, 2022
2,330
2,205
So....
I never said that. Simply that they do not guarantee the quality of the product.
3,916
I know the QUARTS ,yes, REAL Canadian QUARTS, of 10W40 made in 1979 work 100% in my 1957 tractors,also good in my 70isg diesel forklift.
Just have to shake them up good to get the additives into suspension..something Shell didn't tell me about....
imnukensc
BX2380
Sep 10, 2015
613
509
Midlands of SC
Did all fluid/filter changes/cleaned hydraulic suction strainer on my 2380 at 50 hours about 3 years ago. Did it all again the other day at 175 hours. Peace of mind for me.
