This tractor has a brand new engine. Rebuilt with all factory Kubota OEM parts. Most bearings replaced in the transmission, New clutch, starter, alternator, water pump, hydraulic lines, injection pump, injectors, radiator, all coolant lines, fuel lines, seat, headlight, front grill, fuel shut off solenoid, rear lights, 3 loader cylinders rebuilt, one brand new, new bucket, new tie rods, all relays replaced. Everything has been gone over top to bottom. The engine has maybe 3 hours run time. Runs and drives perfectly. Lifts the way it should. All the engine oil and hydraulic oil has been and replaced 1 hour after the fresh build. It was clear as day. The hour meter says 2112. Everything works as it should. Anything appeared questionable was replaced. It is already set up for a backhoe attachment. The hoses are plumbed and the brackets are mounted. I do not have any other attachments besides the bucket. $19,800 obo
