20 year old, Agri-Ease haybob - no shear pin or clutch?
icehorse
L3901, box blade, tedder rake, mini round baler, drum mower, rotary cutter, misc
Aug 10, 2022
156
31
This will be my second year haying. The first time around I was a total beginner. This year, I've catapulted up to not-quite total beginner :)
Last year I didn't even know to think about shear pins or slip clutches. Now that I have a few different PTO devices, shear pins and such are on my radar. It looks like my PTO-poweed haybob does NOT have a shear pin or slip clutch.
Should I be worried? If so, are there any fixes, like - I don't know - some sort of PTO shaft add on?
Thanks!
8,703
Most equipment like that will have sheer pins on the spindles for the turners.
2,013
You can add a slip clutch between the pto shaft and tractor
pto shaft may need to be shortened
8,703
Read the manual on it and it's supposed to have a slip clutch on the implement end of the of the PTO shaft.
If it doesn't have one you might want to consider getting one.
BAP
Dec 31, 2012
2,920
1,032
If it’s like a Kuhn brand haybob, it has a slip clutch. It is built into the drive shaft and is at one end or the other of it depending upon how the driveshaft was installed on the machine.
