2 wire dynamo
IdahoNative
Kubota B7100D 4x4, non-HST, FEL 1630
Jan 12, 2022
114
46
Florida, central
I managed to snag both wires on my two-wire dynamo (B7100d) at the dynamo. Both wires are light blue. I looked at the wiring diagram, but I cannot determine which wire from the harness goes to which wire coming out of the dynamo. I image it matters. Can anyone enlighten me?
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,122
931
Williamstown Ontario Canada
The best thing about this situation is either blue wire does not matter.
If you start at the regulator/ rectifier you should find a harness heading for the dynamo with two blue wires. Connect either blue wire in the harness to either blue wire from the dynamo. There is no correct way.
Usually there is a bullet type connector close to the dynamo for each wire.
Can you post a picture.
Dave
2,154
Both are AC - either way works as Dave explains............. hook em up and fire it up.
IdahoNative
Jan 12, 2022
114
46
Florida, central
Dave
perfect! The two bullet connections nearest the dynamo are the two I snagged. Thank you!
Mowbizz
Bx25d
Aug 19, 2021
439
252
😂 when I first glanced at your thread then title, I thought I read “2 wife dynamo” and thought, oh boy…this should be good!🤣
2,363
The following thread is interesting and on topic. Explains why what Kubota calls a dynamo is actually an alternator. Excellent thread:
