150 gal 3 Point Sprayer
FarmLass1224
Kubota M6060
May 10, 2025
Greenville, Tx
We got the model 800-3PH150NRNB tank sprayer. Pulled it out of storage to start spraying and noticed pressure isn't building. The pump is new and is working. I checked the hoses for any breaks, tighten spots that need it and made sure there wasn't any bad o rings or clogged filter.
Still nothing is working and I'm at my wits end. I got it to work perfectly one day and now it won't start. Any ideas what I'm missing?
Edke6bnl
B7800 Kubota, case 1840 Skidsteer Ford 3500
Mar 31, 2022
259
143
Agua Dulce, California
maybe it needs some priming, I would put some water under pressure into the inlet. I am not familiar with that unit though.
6,739
I dont know that particular sprayer but:
  1. Is the tank fluid circulating?
  2. Have you tried adjusting the pressure relief valve?
hedgerow
455
441
Malcolm NE
Has it worked since the pump was changed? Last one I went to trouble shoot for a guy with no pressure and a new pump he had switched the inlet and outlet on the pump and was trying to put water into the outlet on the pump. If its plumbed right and primed I would guess your pressure relief valve is not adjusted or it is stuck open. The pistons in those relief valves like to stick and won't let the pump build pressure.
