1260 Landpride Rotary Cutter
Blondie70
L2501DT('18)L2501('15)
Aug 6, 2016
256
Poplarville, MS
I guess my mower has lift blades. Bush hogging is a dirty mess here. Every time I cross my gravel driveway or a place under trees with not a lot of grass, I end up in a cloud of dirt/dust.
I have never experienced anything like it. I use the leaf blower on the tractor after working and also use it on ME...there is dirt everwhere.
Anybody else got this dirt problem and working in a cloud of dust problem?
Thanks, Pete in South MS:mad:
8upbowhunter
L4701 FEL, Cutter, Discs and Land Plane
Dec 15, 2016
395
55
S/E Louisiana
Yep, I get the same thing when I hit a dry dusty place.
Grouse09
B2650 Cab, snowblower, FEL, brush hog
Aug 24, 2016
139
Traverse City, MI
Make sure the front of the hog is lower than the rear. May help a little. Other than that, can’t help you.
NBKubota
2650HSDC
Aug 3, 2017
75
New Brunswick
Same here, I've gotten used to giving the tractor a nice clean up after every time I go out cutting! [emoji16]
Sent from my SM-G950W using Tapatalk
Bulldog777
L3200, RTA1266, Modern 5' BB, Mustang 60 FM
Jan 25, 2017
215
Just think of it, after mowing you're a "dirty blondie70"......
Sorry couldn't resist. I get the same thing here too, lots of dust. You might try lifting the mower some, it may reduce the dust, but it won't eliminate it.
I've noticed mowing early in the mornings helps with dust, if the dew is still on the ground. It's REALLY dusty on my zero turn.
mickeyd
Mar 21, 2014
1,192
17
38
Guin, AL
I try to wait until the day after it rains to keep the dust down.
If I could afford it, I would get a cab tractor like they use for roadway cutting.
Blondie70
Aug 6, 2016
256
Poplarville, MS
What about the blades on these things? Are they "lift blades"? I don't remember having this problem with my other tractor and cutter. I wonder if one can buy "regular" blades that don't pickup the dirt & debris and throw it everywhere ??????
I can have my cutter lifted all the way and cross the road and it acts like it's an airplane propeller blowing dirt everywhere.:confused:
Grouse09
Aug 24, 2016
139
Traverse City, MI
I don’t think there are such a thing as “lift blades” for a rotary cutter.
Blondie70
Aug 6, 2016
256
Poplarville, MS
The reason I asked is that my Cub Cadet mower has 'em. I have seen in a catalog that regular non lift blades are available for it. Wondering about the tractor's hog blades':cool: availability.
mickeyd
Mar 21, 2014
1,192
17
38
Guin, AL
You are correct about the blade for the Club Cadet but no such blade for the Bush Hog.
4,807
1,575
Land pride does in fact have a little bit of lift built into the blades. It creates air flow under the cutter deck which helps evacuate cuttings. Also helps stand the grasses up so that they are cut better. I do not know if they offer a straight blade or not. I haven't looked on their web page yet.
Redhooker
East central Florida
Above is correct, the 1260 does have a lift-style blade set, at least mine does. This particular model is probably the worst rotary cutter I have ever used. I will be replacing it ASAP.
