New BX Oil leaking from front hydraulic connections.
WillyY
BX2680
Feb 11, 2024
Columbus Ms
Hello team Kubota, have a BX2680 and Hydraulic oil is leaking from my front hydraulic quick connect lines.
Last week I was using the loader and suddenly the quick connect opened slightly. I was not able to close it by hand and of course could not disconnect the loader to investigate! Ultimately I was forced to close it with a prybar and then could operate the hydraulics and disconnect the loader from the machine. I found the close "Holding" pin was bent and allowed the mechanism to open! It broke off when I disconnected the quick connect. I will go back to have a look at it this week. It appears the leak is coming from the first connection closest to the seat, and is very small.
Is there something I can do to correct it at home?
Thanks
